jeremyh Posted February 3, 2007 Share Posted February 3, 2007 Hi all, Last weekend I took my dash apart to replace the existing Sony CD player with my (much better) Alpine one. I had to undo the majority of all the connectors at the back of the dash panels (as you'd expect), and had great fun trying to get every one back in its' rightful place when I put the thing back together. I'm not sure whether I've not plugged something in or whether I've blown a fuse, but the following is now not working (when it was working fine before): Interior courtesy light Boot light Light ring around ignition Light ring on driver's door (outside) I've downloaded the appropriate wiring diagram but can't seem to make much sense of it. Would I be right in thinking all of the above sits on the same circuit? If this is the case, is there a connector behind the dash that I may have missed or is it more likely that a fuse has blown? Any help would be appreciated Jez Quote Link to comment Share on other sites More sharing options...
Bob Posted February 3, 2007 Share Posted February 3, 2007 Unless you disconected the dash when you took it apart / put it back together, you may have blown a fuse. Check the fuses down in the driver's footwell Quote Link to comment Share on other sites More sharing options...
Mike M Posted February 4, 2007 Share Posted February 4, 2007 I'm pretty sure the fuse for all them is in the engine bay labelled DOME orange 7.5A. I think anyway. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted February 4, 2007 Share Posted February 4, 2007 heres a fuse diagram and it tells you exactly where what is hope that helps.Supra Fuses.pdf Quote Link to comment Share on other sites More sharing options...
jeremyh Posted February 4, 2007 Author Share Posted February 4, 2007 Sorted! Fuse number 23 under the bonnet was blown so replaced it with one of the spares. Thankyou Quote Link to comment Share on other sites More sharing options...
