supra Lee Posted September 4, 2006 Share Posted September 4, 2006 My temp guage has not worked since buying the car. So my friend checked the fuse box in the drivers footwell and the engine bay, which are all fine. Then i decided to buy new dials, which fitted today and still no joy. What other possibilities could there be is there anywhere else that i may possibly need to check? Link to comment Share on other sites More sharing options...
Miguel Posted September 4, 2006 Share Posted September 4, 2006 Temp sensor working? Link to comment Share on other sites More sharing options...
gaz1 Posted September 4, 2006 Share Posted September 4, 2006 check the plastic clip connection to the left and behind the fan shroud goes into a pipe or head there mate Link to comment Share on other sites More sharing options...
supra Lee Posted September 4, 2006 Author Share Posted September 4, 2006 where abouts is the temp sensor? Link to comment Share on other sites More sharing options...
gaz1 Posted September 4, 2006 Share Posted September 4, 2006 behind as in towards the engine plastic clip wit a couple of wires on it, brown clip i think Link to comment Share on other sites More sharing options...
Miguel Posted September 4, 2006 Share Posted September 4, 2006 Top water return hose to the rad closest to the head ( ally) you will see 2 sensors 1x 2 pin and 1 x 1pin conectors on the inside curve of this pipe. Its the single pin one that works the gauge. earth the plug out and see if your gauge moves. Link to comment Share on other sites More sharing options...
gaz1 Posted September 4, 2006 Share Posted September 4, 2006 Top water return hose to the rad closest to the head ( ally) you will see 2 sensors 1x 2 pin and 1 x 1pin conectors on the inside curve of this pipe. Its the single pin one that works the gauge. earth the plug out and see if your gauge moves. thats what i mean,t:rolleyes: Link to comment Share on other sites More sharing options...
supra Lee Posted September 4, 2006 Author Share Posted September 4, 2006 Cheers for the help, I don't want to kill the sensor by doing something wrong, what do I have to do to earth the plug? Link to comment Share on other sites More sharing options...
Miguel Posted September 4, 2006 Share Posted September 4, 2006 Yup..The single pin one ( ie the smallest of the 2 temp plugs) . The gauge should shoot up to max so dont do it for too long. Have someone sitting in the car watching the gauge for movement. Link to comment Share on other sites More sharing options...
