bromy Posted July 28, 2006 Share Posted July 28, 2006 Apart from a leak what would be the cause of a pressure drop of 6psi from 38psi on a aeromotive fpr, adjustment locking nut is tight Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 28, 2006 Share Posted July 28, 2006 Pressure drop from when? How are you measuring it? Quote Link to comment Share on other sites More sharing options...
bromy Posted July 28, 2006 Author Share Posted July 28, 2006 Fuel pressure was initially set at 38 static back in march, but last night on the way home ran fine up to 0.5 bar then slightly misfiring upto the max 0.8bar for which it was mapped, had a look at the fuel pressure and it had dropped to 30-32psi, bridged the diagnostic port today and wound it up to 38 again and all is ok, just a little concerned to why this has happened, pressure gauge is on top of the rail Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 28, 2006 Share Posted July 28, 2006 Ah right, just wondered if the 38 was static and the 32 was idling or something, but it sounds like it wasn't. I guess it could be the adjuster has slipped, but you say the nut was tight so that shouldn't have happened. Or a dodgy fuel pump? Quote Link to comment Share on other sites More sharing options...
bromy Posted July 28, 2006 Author Share Posted July 28, 2006 Or a dodgy fuel pump? Walbro nearly 1 year old, but they can go I suppose:rolleyes: Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 28, 2006 Share Posted July 28, 2006 Dunno mate, seems pretty weird. You wouldn't expect an Aeromotive FPR or a Walbro pump to go. Quote Link to comment Share on other sites More sharing options...
TLicense Posted July 28, 2006 Share Posted July 28, 2006 Do you get a repeatable pressure each time you key on or does it fluctuate at all? Quote Link to comment Share on other sites More sharing options...
