19 inch & Judder
dil
 Share
Just had a set of 19in alloys fitted 235*35 on 8.5 & 265*30 on 9.5 , apparently i got the u.k spec brakes on my car, b'cos they have Supra written over them (is that true) SO the alloys at the front wouldnt go on properly. they had to shave a bit of the spokes of the alloy & use a 3 mil spacer, p.s for good measure i got the car lowered with some eibach springs as well.
Now the surprising thing is round town the ride hasnt suffered at all, but once you build up some speed around 70ish + the steering starts to shake?
Has anyone got any ideas, as i'm abit scared to drive my car at speed, and am desperatly feeling the need for speed
"They had to shave a bit of the spokes of the alloy & use a 3 mil spacer" Err scary i would have thought wheel makers build their wheels to very exacting standards for stress cracking ect, how did they Shave a bit off ??????
If you can drive through the vibration i.e. it disapears at say 80-90 mph it sounds like bad balancing. however this may not be down to the wheels the spacers may be out of balance or out of line if they do not sit tight on the studs.
I dont know as i would want to drive a 300+ bhp car on a set of wheels that have had the spokes shaved though :shocked:
Quote: from dil on 8:50 pm on Oct. 22, 2001[br]Just had a set of 19in alloys fitted 235*35 on 8.5 & 265*30 on 9.5 , apparently i got the u.k spec brakes on my car, b'cos they have Supra written over them (is that true) SO the alloys at the front wouldnt go on properly. they had to shave a bit of the spokes of the alloy & use a 3 mil spacer, p.s for good measure i got the car lowered with some eibach springs as well.
Just take it straight back to the people who did the work and get them to fix it.
My first J-Spec Supra had UK brakes and I had to have spacers fitted so that the wheels would go on.  Fitting spacers obviously means longer studs, they did fit longer studs didn't they???  If not then I wouldn't drive it until you've got some!!!
Even with the spacers/studs and the balancing done, I was never happy with the overall handling of the car, it never felt "right".
As for "shaving a bit off the spokes" of the alloys, well......:shocked:
A quality wheel should be very well balanced before you add a tire. So unless  the removal of wheel material was done with the balance in mind, and effectively they were rebalanced before the tires were put on you may have problems. IMO
I suspect that  any  manufactures guarantee is now void, unless they carried  out the work.
(Edited by Phil Wall at 12:03 pm on Oct. 23, 2001)
I spoke to a national and  reputable alloy wheel dealership this afternoon. They would not alter the wheels in any way to make them fit a car, however they would use added spacers. They were very concerned that any outlet would grind into wheels to make them fit. They suggested  that the manufacturer would go ape shit if they knew what was going on.
I would suggest that you contact the wheel manufactures tell them what the fitter has done and ask their advice. If, as we suspect, the manufacturer says they have buggered the wheels, then have the garage for not  providing merchandise of adequate quality. Then get in your car on your old wheels and get the hell out of there.
I still think it's a wind-up. No one would do anything so blatantly dangerous.
I reckon this sounds like the spacers are causing the problem because the wheel isn't centering properly, its probably spinning round like an egg. I had a similar problem with my turbo Mini a long time ago and thats what it was. I would NEVER fit spacers to any car ever again.  Wouldn't recommend shaving your wheels down either. Take them back to the suppliers and get them to sort it.
Cheers
Paul
Guys cheers for all your replies, now you've all got me seriously worried, the set i've got fitted are millie miglia Evo, ( has anyone else got these fitted, i've seen them on two other supra's but only in passing so wasn't able to ask if any work had to be done to  get them on). To be honest i am rather new at this game, and will be contacting the supplier a.s.a.p, to air my (your) worries.
p.s. can my life get much worse, filling up in petrol staion today, a transit drivers , gone scraped along the entire drivers side of my car!!
  • 2 weeks later...
Yeah but you still have wheels that have been ground down!!
Have you checked that this isn't going to lead to stress fractures??
Out of interest do you know how much weight was needed to balance the wheels ??
Heavy weights shouldn't be necessary unless there is a problem.
Quote: from dil on 8:50 pm on Oct. 22, 2001[br] ...apparently i got the u.k spec brakes on my car, b'cos they have Supra written over them (is that true)...
As a matter of interest, is this true?   (since my J-Spec has these)
I've never compared directly with another J-Spec that I knew had Jap brakes.
Some  J specs came with a sports pack; 17's and uprated brakes, same as UK.
If you had 16's you will have Jspec brakes which only have Supra logo written on the front  caliper.
Yeah i know that still worries me, so i've gotta guy coming down from mille miglia uk to check the wheels out this friday if he gives them the all clear, then i'll finally be able to sleep at night.
p.s. lust from what the other have said i guess i've got this "sports pack", i had originally fitted the 17's and have supra stamped on the front and rear brakes. Have you got a 6 speed gearbox b'cos mine's a real struggle in the cold especially 1st to 2nd
cheers
The manual gearbox can give you sh*t between those two gears especially in 1st and 2nd. You have to give it some slack as the box itself is nigh on indestructable!
Change the oil in the gearbox if you haven't already, as you never know when it was done last. ONLY USE THE CORRECT TOYOTA V-160 OIL...DO NOT USE ANY SUBSTITUE OIL.
Your local toyota garage will get you the right stuff though it will probably take a couple of days to come in. (they will need your chassis/frame no. so have it written down ready.)
If your gearbox does fail (V. UNLIKEY - no matter how agricultural the gear change seems) it has no servicable parts. You will have to buy a new one from Getrag or Toyota that's about £6k down the plug hole!
Look after your gearbox and you'll never need to change it....oh and make sure there is no loose carpet under your clutch pedal as that'll screw the gear change!
Have fun....ps the gearbox oil is about £25 per litre and you'll need at least 2 to fully flush the old oil out.
Laters
Mine's a 5 speed.  Haven't had too much problem with 1st-2nd, but if I pull up to lights and stick it in neutral I sometimes have a little trouble engaging first, and just jam it in 2nd instead.  I love how reassuringly solid the box feels, I've driven cars where you could be in gear and still waggle the gearstick like you were in neutral!
£6k for a gearbox?!   :o
Do you know if that only applies to the 6-speed?   When I had my car serviced the Toyota engineer said they could service the 5-speed (is it the same as a Lexus?) but that the 6-speed was a full replacement jobbie.
It sounds likely that the 5-speed is a generic toyota jobbie, whereas the 6-speed was only ever fitted to the TT supra.
Think about the BHP involved - 225 for an NA, you can imagine cars like Celica turbos and things delivering that power.  ~300bhp from a TT would require something a lot stronger, hence the bespoke unit from Getrag.
Bearing that in mind, it's likely that there are some serviceable items in what is an "average" toyota gearbox, whereas they would probably not have a clue when it came to an ultra rare 6 speed.  Especially as it's so strong that it hardly ever breaks!
 Share
