Toad total closure
green_dragon
 Share
Just a qick question, Does anyone have the wiring diagram for the Toad Ai606?
When I got it fitted, the ''expert installer'' said they couldn't fit total closure because it would be impossible to get the wires into the doors.
After fixing my drivers window motor yesterday, I found it to be dead simple.
I can find out which the switch wires are, and I know I will need a relay to avoid both windows operating under norml use.
So I just need to know which wire is the control wire from the alarm.
Any ideas guys (Mr Harwood)
Chris
The Toad Ai606 only has a total closure output for those car already fitted with it, ie some BMW, VW, Vauxhall, Jaguar etc.
For the Supra, you need a proper window closure module. You'll need to connect a 12v, earth, negative trip from the alarm, (white wire, programmed to be an 'Armed output'), then two wires into the drivers door for the drivers window, and the two wires for the passenger window, you can pick up inside the car from the drivers door wiring.
Yes I do! :thumbs:
Is it in an email'able format mate cos I would really like a copy. I'm not mine's been wired up properly as some of the features dont work as they're supposed to, i.e I can't ommit interior sensors, and every time the alarm sounds the LED blinks twice - optional sensors.
So can I buy, borrow or steal a copy please??
Chris
 Share
