Stealth-1JZ Posted March 12, 2009 Share Posted March 12, 2009 Well i went out this morning to get the soarer mapped The results @15psi were 291 rwhp 370 ft/lbs est. 350hp @ the fly Here is a HPxSPEEDxTORQUE sheet http://img217.imageshack.us/img217/9226/roadspeed.jpg Out on the road when i plant the right foot there is a good bit of a delay before it starts to move. The mapper said it’s almost like a slipping clutch. Could this be a sign the converter or gearbox is on its last legs? Or something else/worse Modifications: blitz BOV Apexi power intake A01B LSD blitz nur spec R cat back and decat Greddy spec R FMIC walbro pump aremotive FPR e-manage blue e-o1 boost controler @ 15psi std 380cc injectors denso ik22 plugs Link to comment Share on other sites More sharing options...
bondango Posted March 13, 2009 Share Posted March 13, 2009 (edited) There actually quite good numbers for 1bar. Especially the Torque figure which is around 40 more than i woulda expected. Damo, does she seem to Rev out without moving if you know what i mean? Whens the last time she had a fluid change? I would look at shimming the box and installing a cooler, as you know they can be a lazy box Edited March 13, 2009 by bondango (see edit history) Link to comment Share on other sites More sharing options...
Stealth-1JZ Posted March 14, 2009 Author Share Posted March 14, 2009 exactly what it dose say im siting at 30kph/2500rpm and plant the boot,shell rev to around 5K rpm hit a bar and away she goes like shit off a shovel LOL but doseant realy move till it hits a bar/5K rpm Cihan a realy good emanage maper in OZ sugested it was due to the factory computer pulling timing because of knock onset by .. too much timing. said to try progressively pull 3-5 above 4.0v degree's between 3000-4500rpm and go from there ? i have allready looked at a cooler,ATF temp gauge,rebuilt valve body and better converter. if i get them you know ill be right up to you to fit them as u have done most of the work on the car so far ? LOL oh and i changed the 2L or so of dex II in the box sump the day before the map Link to comment Share on other sites More sharing options...
bondango Posted March 14, 2009 Share Posted March 14, 2009 (edited) Ahh Mr Cihan Aday, didnt know he was still working with emanage's is it a recent thing? been a while from i drove it lol but i remember it went like shit of a shovel to a hair under a bar...I could understand retard due to knock if anything above 12psi or So but not in the lower boost regions unless whoever was mapping it (Nick?) has it running pretty lean down there and its knocking its tits off. Also, how are the gear changes? as the shift retard will greatly be effected if she is knocking I woulda also suggested manually locking the coverter up on the dyno to see if it made any difference Did you get an AFR printout, and where they checking for DET? Edited March 14, 2009 by bondango (see edit history) Link to comment Share on other sites More sharing options...
Stealth-1JZ Posted March 18, 2009 Author Share Posted March 18, 2009 no i never asked for the AFR print out but i can ask nick for it id say as i know it was mesured.when mapping nick was checking for DET allright ya Cihan is still active on soarercentral down under and dose alot of the mapping on there for members. are you comeing to galway marty ? i think actuly experanceing the prob would better explane it Link to comment Share on other sites More sharing options...
garethr Posted March 18, 2009 Share Posted March 18, 2009 Ahh Mr Cihan Aday, didn't know he was still working with emanages. Cihan seems to be quite busy http://etuner.com.au/ Link to comment Share on other sites More sharing options...
bondango Posted March 18, 2009 Share Posted March 18, 2009 Cihan seems to be quite busy http://etuner.com.au/ Indeed he does Gareth!!! could explain why i hadnt seem him around the old boards as much...1uz turbo kit Mmmmm Link to comment Share on other sites More sharing options...
bondango Posted March 18, 2009 Share Posted March 18, 2009 no i never asked for the AFR print out but i can ask nick for it id say as i know it was mesured.when mapping nick was checking for DET allright ya Cihan is still active on soarercentral down under and dose alot of the mapping on there for members. are you comeing to galway marty ? i think actuly experanceing the prob would better explane it Galway may happen for me..next week will decide though, hopefully if there is a God Link to comment Share on other sites More sharing options...
