Wobbly Auto Stick
Guest Garfy
 Share
Hi peeps,
I've noticed recently that I can wobble my auto stick left to right, I'm sure it didn't do that before, I've had a quick look and can't see a way of getting to anything without taking the T-shaped knob so to speak off, how do you get it off? and does anyone know what might be causing it to have play in it?
thanks
Garath
Edited by Garfy (see edit history)
I believe it fits on a sleeve with a grub screw. So the screw could've come loose. So to speak. :D
I'll try find the thread that explains changing the lever to the Levoc item, which will answer everything. :)
that will be great if you can :)
well, I've checked that and it wasn't loose, its the actual metal shaft, I'm guessing there is a bush at the bottom somewhere, probably accessed from below, does anyone have an exploded assembly drawing for it?
  • 2 months later...
part number is 90385-11003 they come as singles so you will need to order 2, if your stick has any play at all then they are worn, its not a difficult job to do, it took me about an hour.
  • 1 month later...
 Share
