Injector O-rings
cheekymonkey
 Share
The ones you've lost, need replacing. They cost pence so I would just get a complete new set. Safest bet is to try and get them from Toyota so that you know you're getting ones made from the right material.
I just got a quote for the little insulators - indeed they cost pence - 522 pence EACH. That's over £30 for a set of 6 tiny rubber grommets. What are Toyota playing at :taped:
£30 or flames engulfing the car..... hmmmm
I did a list of the types of rubber you could use for fuel o'rings. If you get the wrong ones, they'll probably not leak now, or even in a weeks time. It'll be as you're cruising along the motorway not expecting it when one will finally let go and you'll end up with a petrol fountain underneath the bonnet.
Wherever you get them from just make sure they're good for the type of fuel you'll be using.
I thought these little o-rings at the back aren't even in the fuel path? They just butt up against the retainers to stop vibration?
Correct, Tony is refering to the larger ones that seal the injector to the rail.
The ones on the top are just anti vibration buffers.
 Share
