Guest sonic Posted December 12, 2006 Share Posted December 12, 2006 hey, was wondering if anyone could point me in the right direction on where to look on sorting out my n/a jspec '94 supra. When acelerating hard sometimes it hits about 5000 rpm then the cam kicks in and accelerates hard, other times it doesn't and seems flat or hesitates then kicks in i've only just bought this car , had a mk3 n/a auto previously ( which blew the head gasket ) so i'm a newbie to this engine.... Thanks Link to comment Share on other sites More sharing options...
Rob Posted December 12, 2006 Share Posted December 12, 2006 '94 wouldn't be VVTI would it? Surely not. Link to comment Share on other sites More sharing options...
Guest sonic Posted December 12, 2006 Share Posted December 12, 2006 its the e-jza80 model if thats any help Link to comment Share on other sites More sharing options...
Rob Posted December 12, 2006 Share Posted December 12, 2006 It's just I thought the VVTI came in around 97-98. The NA does give most of its "power" around the 5000rpm range, but it's not a change in cams kicking in, in the non VVTi engine. When was the last service, air filter change etc etc? Link to comment Share on other sites More sharing options...
Digsy Posted December 12, 2006 Share Posted December 12, 2006 Possibly the valve that controls the two-sage intake manifold isn't working properly. If you look down between intake runners 3 and 4 you should see a vacuum actuator operating a lever. Maybe the vacuum hose is leaking. Link to comment Share on other sites More sharing options...
Guest sonic Posted December 12, 2006 Share Posted December 12, 2006 full service just under 3k ago , cam belt was changed about 18k ago. Does feel like cams tho , its a definate "kick" when it hits 5k when its running properly Link to comment Share on other sites More sharing options...
bromy Posted December 12, 2006 Share Posted December 12, 2006 Possibly the valve that controls the two-sage intake manifold isn't working properly. If you look down between intake runners 3 and 4 you should see a vacuum actuator operating a lever. Maybe the vacuum hose is leaking. Yep good call, normally operates between 4500-5000 and gives the extra kick, could be a bit sticky give it all a good clean and check the vac pipe to it Link to comment Share on other sites More sharing options...
Guest sonic Posted December 12, 2006 Share Posted December 12, 2006 thanks for the info guys , shall give it a look when this weather improves a little Link to comment Share on other sites More sharing options...
blitz supra Posted December 12, 2006 Share Posted December 12, 2006 Did you have new leads . plugs, in the service Usually the Rotor Arm and dizzy cap gets over looked too in most cars, maybe worth taking the cap of and having a look what condition its in, The NA as you say kicks in around 5 -5500rpm, However with my new intake pipe the car has totally changed, and it pulls hard from 3500 in mine, Appears the NA responds very well to induction changes, but if you look inside the standard pipe that maybe why, you tend to find this on many Jap cars, the intake and exhausts are very restrictive(especially so in the Skyline) but hey they are restricted to 180kmh (112mph) out there so they don't need to be great i suppose hence the huge tuning market. Link to comment Share on other sites More sharing options...
Supradan Posted December 12, 2006 Share Posted December 12, 2006 I had a similar problem with my old NA it was the vac pipe to the butterfly valve that opens at 4500rpm. There is a pic on here somewhere that shows the valve its in the y section of the intake manifold. It is supposed to close at low revs to give you more torque and open at higher revs,my vac pipe had fallen off. Link to comment Share on other sites More sharing options...
Guest sonic Posted December 13, 2006 Share Posted December 13, 2006 Did you have new leads . plugs, in the service Usually the Rotor Arm and dizzy cap gets over looked too in most cars, maybe worth taking the cap of and having a look what condition its in, ..but hey they are restricted to 180kmh (112mph) out there . checked + in good order . heh i made sure it wasn't restricted driving it back the day i bought it There is a pic on here somewhere that shows the valve its in the y section of the intake manifold i've searched but cannot find the pic , altho i found the valve and i can't see anything wrong with it so far, no tubes missing etc , maybe have to take it off and look closely.... Link to comment Share on other sites More sharing options...
Rob Posted December 13, 2006 Share Posted December 13, 2006 Always keep your pipe clean for good performance. That's what my nan used to tell me, and she was one of SE Londons most experienced prostitutes. Link to comment Share on other sites More sharing options...
Guest sonic Posted December 13, 2006 Share Posted December 13, 2006 Always keep your pipe clean for good performance. That's what my nan used to tell me, and she was one of SE Londons most experienced prostitutes. LOL! Link to comment Share on other sites More sharing options...
