R154 Conversion - Auto TT
snippyt
 Share
Hi,
As title, thinking of doing an R154 Conversion on my Auto TT.
The list of parts that I think are needed are as follows (Please correct if wrong):
-R154 Box
-1JZGTE Bellhousing
-1JZGTE Flywheel
-1JZGTE/7MGTE Clutch
-Front part of the mk3/R154 prop
-w58 gearbox mount
-Shifter extension
-Clutch pedal / Master cylinder
Can anyone help me with a few things:
-Propshaft - Will the above setup work or is it a matter of getting a prop made?
-Gearbox crossmember & Mount - What setup will work, if any?
-Clutch pedal - I've read a write up where someone uses a MKIII pedal with a MKIV master cylinder....Any reason for this setup or can you just use the MKIV pedal and cylinder?
Here is the write up where the guy used a MKIII pedal with a MKIV master cylinder:
http://www.celicasupra.com/forums/showthread.php?66132-TurboMini-s-MKIV-Supra-Auto-to-R154-conversion
Any help is appeciated,
Cheers :helpsign:
Hi Nick
The above prop setup will work, MK3 front and rear half of your current prop.
Gearbox mount - W58 mount will line two holes up, use the lower part of your auto mount.
You can use all of the MK4 clutch parts, just a custom line needed to the slave cyl.
Don't forget the speed sensor, not cheap. Search for Marlin Crawler, he makes a cable > leccy converter.
Ben
 Share
