Spoony Posted December 5, 2007 Share Posted December 5, 2007 hi who has some informations about the hack of the emanage blue to log the a/f ratio??? thank you Link to comment Share on other sites More sharing options...
couv3z Posted December 5, 2007 Share Posted December 5, 2007 didn't know there was any but this could be interesting Link to comment Share on other sites More sharing options...
bondango Posted December 5, 2007 Share Posted December 5, 2007 You will need the .NET framework to run ths, not sure which version, its quite tempermental. Use the Secondary Airflow input wire on the Emanage to log the 5v from the Wideband. Should work with all Firmware versions IIRC http://specialists.supras-ireland.net/Greddy/emanagetool.rar Marty Link to comment Share on other sites More sharing options...
dini_the_owl Posted December 5, 2007 Share Posted December 5, 2007 yep ive done mine. apparently blue to gold? its a bit tricky soldering/shorting the pins on the chip but the jumper is easy enough to do. The only thing i have found is that im better off logging with emanage tools and then converting it to excel form, data is much easier to read and emanage tools is very accurate with my visual wideband gauge, the greddy software does not log accurate to my gauge,even when i set the parameter in the options 0-5v etc, this makes me believe there is somewhat of a glitch in the software conversion factor. p.s if you do it make sure your running the box standard firmware, do the mod and upgrade firmware after. Link to comment Share on other sites More sharing options...
