fastisnice Posted June 24, 2002 Share Posted June 24, 2002 Right, Its time for a replacement of my turbocharges as they 've gone..I was thinking of 2 hybrids which they won't blow my bank account(My mechanic reckons they will only cost £150 more per turbo than standard turbo's).But I was thinking once i'm changing them to stick a big single one..Will I get a lot more power out of it?? Company which sells them reckon is good enough for 600bhp+ though I dont want to go mad with internals as i don't have the budget for it.What kind of power can i expect without having to change pistons etc...(I know i will need a pair of cams and few more bits). Link to comment Share on other sites More sharing options...
GavinL Posted June 24, 2002 Share Posted June 24, 2002 Originally posted by fastisnice Right, Its time for a replacement of my turbocharges as they 've gone..I was thinking of 2 hybrids which they won't blow my bank account(My mechanic reckons they will only cost £150 more per turbo than standard turbo's).But I was thinking once i'm changing them to stick a big single one..Will I get a lot more power out of it?? Company which sells them reckon is good enough for 600bhp+ though I dont want to go mad with internals as i don't have the budget for it.What kind of power can i expect without having to change pistons etc...(I know i will need a pair of cams and few more bits). I assume that you are running a j-spec car with the smaller injectors. Firstly there is no way you could run even the smallest of single turbos on a stock J-spec car. The fuel system is not up too the job of a single and only just do the job of hybrids running low boost (e.g below 85% injector duty cycle). In order too run hybrids at reasonable boost you would need too consider: 550cc injectors + coil packs (secondhand) uprated fuel pump fuel computer water injection or uprated Intercooler If you were going for a single turbo: Single Turbo with manifold 680cc+ injectors Fuel rail uprated fuel pump fuel computer/piggyback ecu uprated Intercooler oil cooler friendly insurance company Paul Whiffen has recently installed a single turbo and may add a few things I have missed. What is your budget? Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 24, 2002 Share Posted June 24, 2002 I don't think a single turbo and hybrids are comparable. The hybrids have a purpose in that they are a reasonable upgrade on the stock system, whereas the single is a fairly large (read labour and system intensive) upgrade. All IMHO of course. Link to comment Share on other sites More sharing options...
fastisnice Posted June 24, 2002 Author Share Posted June 24, 2002 Im not sure at the moment,i 've got already an F-CON pro from my previous car and i'm aware about all goodies which i need for 600+. Not sure of my budget as im in the process of getting a new job.But i think i would like to spend around 5K to get at least most of the list (upgrades).. Link to comment Share on other sites More sharing options...
fastisnice Posted June 24, 2002 Author Share Posted June 24, 2002 Do u think that you can get away with a water spray instead of a big intercooler?? Link to comment Share on other sites More sharing options...
Syed Shah Posted June 25, 2002 Share Posted June 25, 2002 Originally posted by fastisnice Do u think that you can get away with a water spray instead of a big intercooler?? No, in a word. But as long as the stock IC is in good condition, it would do for running hybrids (but not an ideal setup). WI is additional protection rather than the only protection. Link to comment Share on other sites More sharing options...
GavinL Posted June 25, 2002 Share Posted June 25, 2002 Originally posted by fastisnice Im not sure at the moment,i 've got already an F-CON pro from my previous car and i'm aware about all goodies which i need for 600+. Not sure of my budget as im in the process of getting a new job.But i think i would like to spend around 5K to get at least most of the list (upgrades).. Obviously there would be labour charges and you would need better brakes and fatter tyres. Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 27, 2002 Share Posted June 27, 2002 You won't do it properly for 5K. Stay with the Hybrids, or raise the budget! Link to comment Share on other sites More sharing options...
fastisnice Posted June 27, 2002 Author Share Posted June 27, 2002 Has anybody got any idea what BHP can i get out of 2 decent hybrids? and how much are they going to cost me?? (regardless of the rest(FMI,F-CON etc)- I have heard with camshaft,FMIC,F-CON and hybrids around 450bhp?? Would it be possible to get 500bhp out of the hybrids? Link to comment Share on other sites More sharing options...
Syed Shah Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by fastisnice Has anybody got any idea what BHP can i get out of 2 decent hybrids? and how much are they going to cost me?? (regardless of the rest(FMI,F-CON etc)- I have heard with camshaft,FMIC,F-CON and hybrids around 450bhp?? Would it be possible to get 500bhp out of the hybrids? Well, I think a well setup Supra on stage IIIs could easily get over 500bhp, but making a car well setup is an expensive business, FMIC, oil cooler cams etc etc Link to comment Share on other sites More sharing options...
paulrenn Posted June 27, 2002 Share Posted June 27, 2002 Hey Syed What price typically are FMIC's? Price range? It seems that, whatever performance parts cost for other cars, for the Supra it is about double!!! I'm thinking of getting some FMIC kits made up here. I had a custom one built for my GT-Four and I was very happy with it, made a great difference. I could never get my manifold temps about 40C even on the rolling road. The quality is good. Its not show quality, all polished pipes and shiny lacquer, but it gets the job done for a very reasonable price. If there is enough interest, I would be willing to get a kit made up for my car as a prototype so that all the patterns were available, then its just a matter of getting my fabricator to make them up to order. I think if I could get them done for a good price, then there might be a lot of interest from the USA too. For examples of the Celica FMIC, see my website, click Custom Parts. Prices should be similar to the Celica prices shown there. Link to comment Share on other sites More sharing options...
fastisnice Posted June 27, 2002 Author Share Posted June 27, 2002 As far as i know there are 2 types of FMIC one is good enough for upto 550bhp and cost around £700 and the other one is much bigger and cost £1300.In my opinion get the bigger one because one day all supras must be over 500bhp(hihihi) :):) Link to comment Share on other sites More sharing options...
paulrenn Posted June 27, 2002 Share Posted June 27, 2002 Actually, there are many, many different kits offered by the manufacturers. £1300 for an FMIC is insane IMHO...unless someone wants to pay me that to make a kit up, in which case I would say it is very reasonably priced indeed... Link to comment Share on other sites More sharing options...
Alex Posted June 27, 2002 Share Posted June 27, 2002 You can get an ordinary FMIC made 600x300x80mm for about £300 if you go to the right people...hard pipe kit would be another £150 max. Add £500 to the bill and you can get a bar and plate style one which would be about 25% more efficient...which is a hell of a lot when you consider its just air flowing past a lump of metal dragging away heat. If you can, get the best (not necessarily the largest) FMIC you can. As for £500hp on hybrids...well that is possible but you'd have to be really determined...why cause of the restrictive nature of the exhaust manifold and head exhaust ports. They quickly become a restriction on the system which causes heat build up and simply can't flow enough gases out of the way. If you get the head ported, some high lift long duration cams and get a custom manifold then 500hp could be made possible with the fuel system mapped correctly. But then you would have just spent the same amout as you would need to buy a Single Turbo kit. I would wait a bit a fit a bigger kit...do it properly once. PHR Stage 2 Fuel Kit + Sound Performance SP66 would be my choice I think they are about 6k to buy and that would be a 600hp kit with bells on. FMIC - 1k max DO NOT PAY MORE Fuel Kit - PHR S2 $2800 (£1850) + shipping Turbo - SP66 $5500 (£3600) + shipping + Installation (or do it yourself if you have the patience) Link to comment Share on other sites More sharing options...
Syed Shah Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Alex Holdroyd As for £500hp on hybrids...well that is possible but you'd have to be really determined...why cause of the restrictive nature of the exhaust manifold and head exhaust ports. They quickly become a restriction on the system which causes heat build up and simply can't flow enough gases out of the way. If you get the head ported, some high lift long duration cams and get a custom manifold then 500hp could be made possible with the fuel system mapped correctly. But then you would have just spent the same amout as you would need to buy a Single Turbo kit. I would have to disagree with you here Alex. A full BPU car in the states dynos around 430rwhp SAE, equivilent to approx 430bhp DIN. So, add the 30% power gain that a well setup pair of hybrids can provide, and you get 559bhp or approx 447rwhp. If what you say is true, hybrids would give little more than a full decat + exhaust system. Link to comment Share on other sites More sharing options...
paulrenn Posted June 27, 2002 Share Posted June 27, 2002 FMIC - 1k max DO NOT PAY MORE Fuel Kit - PHR S2 $2800 (£1850) + shipping Turbo - SP66 $5500 (£3600) + shipping + Installation (or do it yourself if you have the patience) [/b] These prices are making my head spin!!! What's in each of these kits? Itemise them for me and I can almost guarantee I can do similar for much less... FMIC should be more like £600 Fuel system should be simple, 6 injectors, a custom rail, and some hoses. Turbo - hope that includes manifold and downpipe?! Of course, as the US cars make 200% horsepower as rest of the world, the prices are bound to be higher Link to comment Share on other sites More sharing options...
GavinL Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Syed Shah I would have to disagree with you here Alex. A full BPU car in the states dynos around 430rwhp SAE, equivilent to approx 430bhp DIN. So, add the 30% power gain that a well setup pair of hybrids can provide, and you get 559bhp or approx 447rwhp. If what you say is true, hybrids would give little more than a full decat + exhaust system. Emma and Martins car looks too have recorded about 325 rwhp on the MIRA dyno (see members page). What does that make it if you use this figure? Link to comment Share on other sites More sharing options...
Alex Posted June 27, 2002 Share Posted June 27, 2002 Power increases don't follow a linear path....as you take away one restriction you just move onto the next one. 430hp maybe possible but it aint just a bpu car! That's over 100bhp more than stock! Or did you mean BPU+++??? Link to comment Share on other sites More sharing options...
Syed Shah Posted June 27, 2002 Share Posted June 27, 2002 Well, theoretically, with 20% drivtrain losses, it would make the car around 390bhp. Add stage III hybrids, and this would be around 507bhp or around 406 at the wheels, and their car is not ever full BPU (FMIC etc). Link to comment Share on other sites More sharing options...
Syed Shah Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Alex Holdroyd Power increases don't follow a linear path....as you take away one restriction you just move onto the next one. 430hp maybe possible but it aint just a bpu car! That's over 100bhp more than stock! Or did you mean BPU+++??? Yep, sorry for any confusion, i meant those with FMICs etc. I dont like all the +s Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by paulrenn Fuel system should be simple, 6 injectors, a custom rail, and some hoses. Yeah plus fuel pump, FPR, filter, briaded hose for full length of the car. The reason a lot of parts for the Supra are expensive is because the specific parts (FMIC's, fuel rails, etc) are not sold in big volumes. Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Syed Shah , and their car is not ever full BPU (FMIC etc). For now. Link to comment Share on other sites More sharing options...
Syed Shah Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Martin F For now. Lol, ill be looking out for a 800hp monster Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by Syed Shah Lol, ill be looking out for a 800hp monster Hey i'm only talking about the FMIC. What do you think i work in IT or something ???? Link to comment Share on other sites More sharing options...
Alex Posted June 27, 2002 Share Posted June 27, 2002 Originally posted by paulrenn These prices are making my head spin!!! What's in each of these kits? Itemise them for me and I can almost guarantee I can do similar for much less... FMIC should be more like £600 Fuel system should be simple, 6 injectors, a custom rail, and some hoses. Turbo - hope that includes manifold and downpipe?! Of course, as the US cars make 200% horsepower as rest of the world, the prices are bound to be higher The 1k was for a very big Bar and Plate design with a full connection kit...this is WRC quality stuff. The fuel systems includes twin pumps which are quite expensive, Seimens 850cc injectors, PHR fuel rail. #6 hose, connectors and even some tools I believe. The Turbo kit comes with downpipe, manifold, wastegate, actuator, BOV connection pipes, induction kit..oh and a fekin' large turbo! Full details can be had from the powerhouseracing.com and http://www.sound-performance.com sites Link to comment Share on other sites More sharing options...
