markrzs Posted November 4, 2007 Share Posted November 4, 2007 Could someone please tell me do you have to have the engine running while bledding the brakes ? Link to comment Share on other sites More sharing options...
rob wild Posted November 4, 2007 Share Posted November 4, 2007 Err no i never do. Link to comment Share on other sites More sharing options...
markrzs Posted November 4, 2007 Author Share Posted November 4, 2007 Sorted now, cheers Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 4, 2007 Share Posted November 4, 2007 A little late but when I changed my brakes and lines I had the engine running all the time during bleeding. I think it may have been Mr Wilson that suggested it to help bleed through the ABS system aswell (sorry if im wrong here chris ) Link to comment Share on other sites More sharing options...
Suprash Posted November 5, 2007 Share Posted November 5, 2007 If your engine isnt running then does your brake servo not cease up with pressure.....? Link to comment Share on other sites More sharing options...
Jamesy Posted November 5, 2007 Share Posted November 5, 2007 A little late but when I changed my brakes and lines I had the engine running all the time during bleeding. Yeah that's what i thought Link to comment Share on other sites More sharing options...
markrzs Posted November 5, 2007 Author Share Posted November 5, 2007 Oh right, well i've got to bleed them again anyway as i've got air in there and as a result i've a spongy pedal Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 5, 2007 Share Posted November 5, 2007 If you bleed with the engine running you will have residual pressure on the master cylinder and so will have fluid being forced out as soon as you crack a nipple. Link to comment Share on other sites More sharing options...
markrzs Posted November 5, 2007 Author Share Posted November 5, 2007 If you bleed with the engine running you will have residual pressure on the master cylinder and so will have fluid being forced out as soon as you crack a nipple. So thats a no no to leaving the engine running ? Link to comment Share on other sites More sharing options...
JustGav Posted November 5, 2007 Share Posted November 5, 2007 I've never had the engine running for bleeding the brakes.. Link to comment Share on other sites More sharing options...
