Chris and Alana Posted November 3, 2007 Share Posted November 3, 2007 Well I have looked into this and all the previous threads I could find all recommended Toyota type 4 auto transmission fluid. To cut a story short I went to my local toyota dealer this morning just to be told they dont sell the stuff and that any ATF fluid would do. I told the guy that I didnt know what was in there to start with but it would probably be type2 or type4 and I told him that I heard type3 doesnt mix very well. He then ploded away and came back and said the same thing (any ATF will do) and then told me that they just use BP stuff and that they have had a few supra's in before and used that stuff and all was good (which may be worrying) anyway, is there any alternative to type4 that doesnt cost the earth? All I want to do is change the 2L's in the sump to give a bit of a re-fresh if you like. Would any odf the castrol ATF's be ok (something I can just pick up at halfords) Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 3, 2007 Share Posted November 3, 2007 I went to my local toyota and the same thing happened. "any atf will be ok" he said. I was changing the autobox so all the fluid was drained and needed refilling. So anyway after a bit of thought I decided to just go with what they said. That was back in May, and everything is fine up to press If it does cause some damage, a new autobox is around £200-ish so no REALLY big deal tbh Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 3, 2007 Author Share Posted November 3, 2007 What fluid did you use in the end? Also can using the wrong fluid really do that much damage? Is there something I should really try and avoid Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 3, 2007 Share Posted November 3, 2007 I used the stuff Toyota recommended and use in all their autos...can't actually remember what it was. I've read on here before that using the 'wrong stuff' (whatever that may be) will cause damage, but to what extent I'm not sure of. Quote Link to comment Share on other sites More sharing options...
TrickTT Posted November 4, 2007 Share Posted November 4, 2007 I think Envy sell the proper Toyota atf in 5 litre tubs Quote Link to comment Share on other sites More sharing options...
hoff Posted November 5, 2007 Share Posted November 5, 2007 Any Dexron iii is what you want. The oil man on here will sort you out or his web site opie oils. Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 5, 2007 Author Share Posted November 5, 2007 Thanks for the advise. I think I will use the castrol dexron 3 then for a sump change Easy to get a hold of aswell. Quote Link to comment Share on other sites More sharing options...
