dash removal question.
xeno
I'm hoping to take my dash out this weekend and read that you should disconnect the battery to prevent the airbag light staying on.
I have a 1993 RZ, which doesn't have an airbag.
Should I still disconnect the battery?
If so, would it affect the HKS F-Con V computer's memory, or will that be ok?
Thanks for any help.
I had a test run this afternoon. Pulled the entire dash out and put back in, in under an hour. I even fixed the cigarette lighter while I was at it. Seems the previous owner had forgotten to put the plug back on.
Left the battery connected. I did scare myself with the CD eject button, but not had the horn yet.;)
Ah yes, forgot the cd eject button - I'm usually carefully balancing the dash at that point, top half unplugged, bottom half in the process of being unplugged, then I nearly (every freaking time!) drop the dash panel on the protruding CD and snap it.
