Supradan Posted October 14, 2007 Share Posted October 14, 2007 Will i need colder grade plugs if i de cat and run with a 1 bar restrictor ring.I am not going to remove the fuel cut as i would like to keep the original safety of it.Fuel pump will be ok as car has only done 49k miles ,is there anything else i need to consider cheers all Link to comment Share on other sites More sharing options...
Steviekid Posted October 14, 2007 Share Posted October 14, 2007 My car ran "ok" at 1.2bar with the same plugs as it had when it was stock until I changed them so I would imagine you'd be ok. From the FAQ however: Stock TT NGK - BCPR6EP-11 - gap to 1.1mm PLATINUM NGK - BKR6E (2756) - gap 1.1mm NGK Iridium - BKR6EIX-11 (3764) leave gap alone Denso Platinum - PK20R11 - gap 1.1mm Denso Iridium - IK20 - leave gap alone TT @ upto 1bar NGK - BCPR7ES (3330) - gap 0.9mm NGK - BKR7E (6097) - gap 0.9mm NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone Denso Platinum - PK20R11 - gap 0.8mm Denso Iridium - IK22 - leave gap alone Link to comment Share on other sites More sharing options...
Steve Posted October 14, 2007 Share Posted October 14, 2007 I would change to some cooler plugs. The NGK BKR7E (6097) gapped to 0.9 - 0.8mm will be fine. They are only about £12 for 6 plugs. Link to comment Share on other sites More sharing options...
