sparkyspar Posted September 23, 2007 Share Posted September 23, 2007 hi all is it normal for my temp needle to reach half way in less than 2 mins after staring from cold ,normal driving too:) Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 24, 2007 Share Posted September 24, 2007 mine usually takes atleast 5-10 mins to reach half way,, have you checked coolant/oil levels etc Link to comment Share on other sites More sharing options...
steb9780 Posted September 24, 2007 Share Posted September 24, 2007 Mine only takes maybe 4 minutes to get warm, depending on how cold the weather is. Probably 4 on a warmi(ish) day and 6 on a cold day. Link to comment Share on other sites More sharing options...
TonyP Posted September 24, 2007 Share Posted September 24, 2007 Mine only takes maybe 4 minutes to get warm, depending on how cold the weather is. Probably 4 on a warmi(ish) day and 6 on a cold day. Doesn't take very long. Link to comment Share on other sites More sharing options...
merckx Posted September 24, 2007 Share Posted September 24, 2007 It does rise very quickly. The engine cannnot be warmed up fully, I don't start using excessive throttle at this stage. That's primarily why I fitted an oil temp gauge. Link to comment Share on other sites More sharing options...
edge Posted September 24, 2007 Share Posted September 24, 2007 It does rise very quickly. The engine cannnot be warmed up fully, I don't start using excessive throttle at this stage. That's primarily why I fitted an oil temp gauge. your water temp will be alot hotter than your oil. Would not give the car any rice before oil is upto normal operating temp. Link to comment Share on other sites More sharing options...
sparkyspar Posted September 24, 2007 Author Share Posted September 24, 2007 :thumbs:cheers all .mind at rest now Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted September 24, 2007 Share Posted September 24, 2007 My stock gauge shows 'normal' after a couple of minutes driving. At this point my aftermarket gauge shows 40degC (sensor in top hose). I think the stock gauge is calibrated to show 'normal' over a wide range of temperature. Oil temp reaches 50degC after about 5 mins driving. Link to comment Share on other sites More sharing options...
