markymark Posted September 19, 2007 Share Posted September 19, 2007 Just signed up for this after meaning to do it since last christmas but the f*#ker keeps losing the server just as I'm getting into a game - anyone have a suggestions, or is this just a 'grin & bear it' feature? Link to comment Share on other sites More sharing options...
Ark Posted September 20, 2007 Share Posted September 20, 2007 I had similar - run your network diagnostics from the system dash board. You'll probably find your NAT setting allow 'partial' NAT, which means flakey connections ahoy. Check that first then you may need to reconfigure your broadband. Link to comment Share on other sites More sharing options...
markymark Posted September 20, 2007 Author Share Posted September 20, 2007 I had similar - run your network diagnostics from the system dash board. You'll probably find your NAT setting allow 'partial' NAT, which means flakey connections ahoy. Check that first then you may need to reconfigure your broadband. I have done what you said and it tells me that my NAT settings are open? Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 20, 2007 Share Posted September 20, 2007 How often does it do it Mark? Every time you play? Do some games work more than others? Link to comment Share on other sites More sharing options...
markymark Posted September 20, 2007 Author Share Posted September 20, 2007 How often does it do it Mark? Every time you play? Do some games work more than others? Only been playing it with Battlefield2 and it crashes every couple of minutes:(. Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 20, 2007 Share Posted September 20, 2007 Could be the game itself mate. Perhaps try another copy or your copy in another 360? If your NAT settings are 'Open' then it's not a port issue which is the most common reason why people can't join certain servers etc... Link to comment Share on other sites More sharing options...
markymark Posted September 20, 2007 Author Share Posted September 20, 2007 I thought at first it might be my firewall or Norton anti virus interfering but doesn't make any difference Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 20, 2007 Share Posted September 20, 2007 If that was the case your NAT status would appear as "Strict" or "Moderate". You wouldn't be able to have voice communications with people on Live and a host of other issues too. Link to comment Share on other sites More sharing options...
markymark Posted September 20, 2007 Author Share Posted September 20, 2007 No problems chatting to anyone. Could it be my Internet provider(Virgin)? Link to comment Share on other sites More sharing options...
markymark Posted September 22, 2007 Author Share Posted September 22, 2007 Solved it:d Switched over to Sky broadband today and not one problem, so Virgin are the problem Link to comment Share on other sites More sharing options...
