Guest Kev Posted August 28, 2007 Share Posted August 28, 2007 I have a few bits for sale Two 15" OZ Audio Matrix Elite Subwoofer Dual 4ohm £160 each or £300 the pair Only been used for about 10 hours http://directice.co.uk/webstore/catalog/product_info.php?products_id=41 ------------------------------------------------------- VIBE MONOBOX 3 400 rms @ 4ohm 600 rms @ 2ohm. had this running a RE SE and was great. It works perfectly, however it has cosmetic damage like scratches and missing the vibe badge. Comes with original box and dust bag £100ono http://www.caraudiodirect.co.uk/vibe-monobox-p-3266.html ------------------------------------------------------------ RE Audio SE12 600W RMS / 1000W Peak Dual 4 Ohm Dual composite 2 piece cone Rubatek foam surround Cast aluminium basket Tork-Tite terminal 4 layer flatwound aluminium voice coil £150 Had this running from the vibe amp. works perfectly, has slight wear on the rubber surround http://www.caraudiodirect.co.uk/audio-se12-p-2962.html --------------------------------------------------------------- Blaupunkt Velocity Burning Desire 2 1 x 1200W @ 4 ohm (0.07% THD) 1 x 1750W @ 2 ohm (0.07% THD) 1 x 2000W @ 1 ohm (0.07% THD) Freq. Response: 10Hz ~ 450Hz S/N Ratio: >95 dBA Dimensions w/endcaps: 22.56" x 10.95" x 2.56" (57.3cm x 27.8cm x 6.5cm) Dimensions wo/endcaps: 18.62" x 10.55" x 2.28" (47.3cm x 26.8cm x 5.8cm) Weight: 15.9 lb (7.2 kg) £200ono ----------------------------------------------------------------- 2x Crystal Pro x212 12" 600wrms Dual 4 ohms subwoofers £80 each or £150 the pair http://www.crystalmobilesound.com/literature/PRO%20X212%20LIT.pdf Link to comment Share on other sites More sharing options...
