Spoony Posted August 27, 2007 Share Posted August 27, 2007 im going on t78 soon and im in front of a big problem, the cooling of my oil. do you have any pictures and details of engine ans transmission oil coolers installed? i need the sizes of the screws and for example of the oil cooler adapter at the oil filter. has the jspec an original oil cooler? engine and transmission? i heard there are some problems with the eu spec model when you go on single and dont remove the original engine oil cooler, and i also heard the jspec doesnt have an transmission oil cooler. any informations would be helpfull. i will go for a 3200 stall and will be arround 550hp Link to comment Share on other sites More sharing options...
Steve Posted August 27, 2007 Share Posted August 27, 2007 Is your gearbox a standard one? Link to comment Share on other sites More sharing options...
Spoony Posted August 27, 2007 Author Share Posted August 27, 2007 yes Link to comment Share on other sites More sharing options...
Spoony Posted August 27, 2007 Author Share Posted August 27, 2007 wont get any help with a standart box or what?? Link to comment Share on other sites More sharing options...
paul mac Posted August 27, 2007 Share Posted August 27, 2007 you should not need an engine oil cooler unless you are track day'ing, you will need 2 decent sized transmission coolers and i would do some research on the hi-stall i run a 500 rwhp T61 with a 3200 which is perfect if you intend to run a T78 you will probably need a much higher stall for such a laggy turbo Link to comment Share on other sites More sharing options...
Steve Posted August 27, 2007 Share Posted August 27, 2007 wont get any help with a standart box or what?? I was thinking the standard auto box wouldnt last that long with that sort of power Link to comment Share on other sites More sharing options...
Spoony Posted August 28, 2007 Author Share Posted August 28, 2007 if the gearbox blows up i still can get a boostlogic. but i think its ok, i only drive 2000 miles a year and will only give more than 1 bar in a fight does anybody have some pictures of the oil coolers? i need to know which oil pipes i have to cut and where. im a little bit afraid off the higher stalls as a daily driven. the t78 has 150whp at 3200rpm. i think this is enought for a quick start. or isnt there a big difference between the 3200/3800 stall? im afraid its to much for daily driven Link to comment Share on other sites More sharing options...
