charlieboo Posted August 27, 2007 Share Posted August 27, 2007 I have recently had my engine rebuilt. I removed and reinstalled it myself. To my joy, it started first time and ran like new. That was, until last night. Engine turns over, but she won't start. Crank & Cam sensors and coil packs are showing correct resistance. There is power to the ignitors, but no spark from plugs. I tried to bridge +B & FP on diagnostics port, but nothing. Speaker cable from positive on battery to FP turns on the fuel pump. +B on diagnostics port shows nothing. Water temp sensor shows nothing (was hot when checked) and there is no power at connector. My question is this, what can I check now?  As she has run, I'm sure this is not the cause, but I have an extra earth strap (same as one on fuel filter). Where does this go? I recall it came from the back of the block, but from where is now a mystery. Link to comment Share on other sites More sharing options...
charlieboo Posted August 27, 2007 Author Share Posted August 27, 2007 Fixed. My FCD had become loose. I would still like to know where that second earth strap goes though? Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted August 27, 2007 Share Posted August 27, 2007 There should be an earth from the back of the engine to the bulkhead. Link to comment Share on other sites More sharing options...
charlieboo Posted August 28, 2007 Author Share Posted August 28, 2007 Thank you very much. Link to comment Share on other sites More sharing options...
