Manual boost controllers
Chris and Alana
Hi guy's, a couple questions on manual boost controllers really. How do you guys with these find they work on the supra? Are they a pain when the temps start getting lower in the winter (do you have to keep changing the setting)? And what about the in-car manual boost controllers. . . I take it they give you abit more controll as they are in the car but do you get the sound of releasing air then inside the car?
...on the other hand, I use two of them (ball and spring) and have always been very happy indeed.
Yes, you need to turn a screw or two if the temperature drops a lot (like summer and winter settings) but that's it.
Simplicity.
Mind you, I'm not too fussy about a psi or two so it suits my needs.
An electronic controller allows you more flexibility and more accurate boost settings, so if that's what you want just go for one.
Simplicity.
Whats the benefit of running two? Do you use one to control each turbo?
