Racelogic launch control problems..any help greatly appreciated!
Austrian Supra
I have my racelogic working in my Supra since about 3 years now, with Phils file and am happy with it.
Last year I built the engine and installed a single turbo setup.
Now I have about 800hp at 1,7 bar.
The car runs strong and the RL seems to work generally, but there´s one thing that doesn´ t since the mods...
The launch control.
I cannot activate it.
Normally I just push the green button and step on the gas….and it revs to where the revlimiter is set.
Since last year, when I did the mods, I can push that button as often as I want….it doesn´t activate the LC . :(
I haven`t changed any wires (as I use the plug and play AEM stand allone), and as I see the light flashing when checking the ABS sensors (fast and faster the fastzer I go), and also
see it flashing when I check rpm signal (faster and faster the higher I rev), it seems all inputs are ok…..and as it reduces power when going WOT in first gear, I see it generally works…
Any Idea?
I also tried to set a new rev limit in pushing the button, then pushig (and holding it) and reving to where I want it to be…….
As long as I hold the button the light flashes (ist that correct?).
Then the revlimit should be set……
But when I try to activate the LC then …pushing the button…………..the revlimit doesn´t work :(
It`s just like I did nothing………..it´s not activated……..
ANY IDEA?
PLEASE help!
I have a race on 1st Sept. and need the LC working by then………….
Thanks a lot in advance!
