DamanC Posted August 5, 2007 Share Posted August 5, 2007 Do they need re-gassing? Had mine about 3 years now and it just does not seem to have the grunt it used to Link to comment Share on other sites More sharing options...
Pig Posted August 6, 2007 Share Posted August 6, 2007 Dont know, all i know is i need one. Couldnt sleep for sh1t last night Link to comment Share on other sites More sharing options...
dibbleyuk Posted August 6, 2007 Share Posted August 6, 2007 I was the same last night mate was bloody horrible! Thing is its only a few nights a year so i will manage Link to comment Share on other sites More sharing options...
DamanC Posted August 6, 2007 Author Share Posted August 6, 2007 It got cold after it got going in the end, im sure it used to be cold f**king freezing within a minuite or so. This year has been crap for air con use the last couple of years i used it nearly every day throughout the summer months. One of those things you think you never need until you get one, then the world ends if it gives up. Link to comment Share on other sites More sharing options...
Guest Blata Posted August 6, 2007 Share Posted August 6, 2007 Yes, all ac units can lose gas, however before any "re-gassing" can be carried out the leak must be rectified, or ozone delpeating gas HCFC,HFC could be released in to the atmosphere European F Gas Regulations Dated 4 July etc etc are now in force however most of these will not effect you as the system is under 3 kg gas charge. Could go on for hours about this subject, basically look for oil on any joints, ie flare nuts usually on the condenser, where the pies come out, and on the back of the indoor unit. As oil is carried around the system with the gas, where the gas escapes a small amount of oil also escapes Link to comment Share on other sites More sharing options...
