NA - T Kit Cost
boombastictiger
Hi, How much would the NA-T turbo kit cost? Not the fitting or labour charges, just the actual turbo kit itself.
I want to buy the kit so that everyday when I wake up I will see it and it will hopefully encourage me to save my money and put it towards getting it all fitted hehe...
But yeah the price of the kit and where can I get it from?
For a 300hp kit with no Engine upgrades your looking around £1600 or so, includes IC kit, turbo kit, Fuel pressure regulator, Walbro pump, SAFC, boost cut limiter, 440cc injectors. Add another £300 or so for a 3mm headgaket and Arp Studs and that should see you to 400hp, though Clutch/autobox and brakes need upgrading then (Clutch would be a good idea no matter if its 300 or 400hp) also the cooling system needs consideration (i.e. oil cooler kit and maybe bigger rad)
