warning light
Jurgen-Jm-Imports
Originally posted by jurgen
ok i have tried the diagnostic check but the check light constantly flashes not a pause, so i cna tell what code it is.
also the car has not got a active spolier as it has been removed
how can i by pass this if it is the spoiler.
thanks
Short out the contacts:conf:
Don't know about the diagnostic Jurgen sorry. If it had a spoiler fitted you should see the two button at the bootm of the drivers console just in front of the gear stick.
Anyway, you need to check if the connections to the spoiler are still there, they are located through the drivers side scoop in the front bumper (assuming its a standard bumper).
You could also play with the spoiler ECU which sits behind the stereo, if the worst comes to the worst you could get the wiring diagram and short out two connectos on that or, take it completely.
It will be the spoiler ECU sending the signal to make the light flash, if it aint there it can't make the light flash can it:)
Do a search on here there is a scanned wiring diagram somewhere.
Hope you get it sorted:)
thanks steve,
it had an aero bumber on a can see the connectiondshave been tape up at the front end and the button in the dash has been taking out, but the connector clip is there behind cd player i have tried to do a search but bit technical sorry to be a pain but can u see if u can locate me a link, doesnt have to be straight away a just want that light out of the way.
