suprattgaz Posted July 19, 2007 Share Posted July 19, 2007 I have had a go fitting the lenses using the original lens, as previously explained, but not pictorally expressed. I have not had time to formally write it up as a step by step guide, but I have taken photos through every step, including the tools I used to do it, so these should help all of you who have bought a pair and not tried fitting already. In brief: remove the original lens using oven, heat gun or hair dryer!!! Leave the rubber around the outside - there is no need to remove this. That means it is a smack on perfect fit when you put them back on the car Cut out the old lens, leaving the lip that holds it to the main body, re-assemble and tape in place, and use small self tapping screws to locate and hold. Loosen the screws and squirt an epoxy or adhesive in the gap. Tighten screws and leave to dry. Remove new lens assembly from main body, carefully and neatly watertight from the rear using silicone. Smooth over the screws on the front with car filler, then sand back, mask and spray around the exterior to hide all your glueing and screwing (it will then look like the original did with a black outline around it). DONE! About 4 hours work per light unit. Don't rush it, it is worth taking the time to do it properly, and they will look the DB's! If you rush you stand a chance of bodging them Moderators - please move to technical if you think this is the wrong loaction for this. Link to comment Share on other sites More sharing options...
Inferno Posted July 20, 2007 Share Posted July 20, 2007 I hope you don't mind some questions, but now I'm even more confused :-( 1.) "remove the original lens using oven, heat gun or hair dryer!!! Leave the rubber around the outside - there is no need to remove this" you mean leave the rubber around the outside of the original lense or the main body? 2.) "re-assemble and tape in place, and use small self tapping screws to locate and hold. " you mean put the new clear lenses on top of the old lip and tape and screw in place? 3.) "Smooth over the screws on the front with car filler, then sand back" this is on the front or rear of the lenses or on the main body? 4.) So basically you end up painting the outside of the clear lense to hide anything showing where it connects to the lip? Thanks! p.s. sorry if these questions seem stupid, it's just not worth taking the risk of screwing up this job :-) Link to comment Share on other sites More sharing options...
suprattgaz Posted July 20, 2007 Author Share Posted July 20, 2007 Not a problem - I am going to re-write the instructions to make it more clear. but basically yes, leave the rubber around the lens, yes screw the new one on front of the old, and fill the front where the heads of the screws are showing. It is ever so easy, i will try and make them more clear, just fired these piccies on last night to try and help. Looks like i may have confused you lot more, sorry!!! Link to comment Share on other sites More sharing options...
rick001 Posted July 20, 2007 Share Posted July 20, 2007 Hi Gaz Excellent write up i found it very informative Quick Q if you can help, i intend to re-furb 1 of my lights as it the dreaded yellowing, when i have heated up the light, does it pop off quite easily and can the rubber be left on while i de-yellow it? Link to comment Share on other sites More sharing options...
suprattgaz Posted July 20, 2007 Author Share Posted July 20, 2007 Hi Gaz Excellent write up i found it very informative Quick Q if you can help, i intend to re-furb 1 of my lights as it the dreaded yellowing, when i have heated up the light, does it pop off quite easily and can the rubber be left on while i de-yellow it? Not just pop, needs prising off. Yes you can leave the rubber on. If they are that yellow it may no clean up at all. Link to comment Share on other sites More sharing options...
suprattgaz Posted August 3, 2007 Author Share Posted August 3, 2007 I have written a new, better version with lots more information. I cannot upload as it is massive due to piccies (13Mb!!!) so will have to wait until I go into work on Monday to change into pdf. Unless anyone has a way of doing it now? It is a word document at present. Link to comment Share on other sites More sharing options...
DamanC Posted August 3, 2007 Share Posted August 3, 2007 There are lots of online PDF converters out there buddy Link to comment Share on other sites More sharing options...
DamanC Posted August 3, 2007 Share Posted August 3, 2007 Or I use this http://www.cutepdf.com/Products/CutePDF/writer.asp Link to comment Share on other sites More sharing options...
suprattgaz Posted August 3, 2007 Author Share Posted August 3, 2007 Wow handy!!! Why did our company just fork out a load of money to get Adobe PDf writer then?!?!?! Ah well..there you go. This is exactly how i did the last lot. Another note, when cutting this stuff it tends to melt, so using toothed tools works better than abrasives.Guide to fitting clear lenses part 1.pdfGuide to fitting clear lenses part 2.pdf Link to comment Share on other sites More sharing options...
Guest Chich Posted June 8, 2009 Share Posted June 8, 2009 Has anyone found a way to fit the lenses without the screw method? Link to comment Share on other sites More sharing options...
jay5041 Posted June 8, 2009 Share Posted June 8, 2009 looks good i just purchased some of these off P_17EED so should come in handy Link to comment Share on other sites More sharing options...
suprattgaz Posted June 9, 2009 Author Share Posted June 9, 2009 Guide for you lot....Fitting guide.pdf Link to comment Share on other sites More sharing options...
