250horses Posted October 25, 2004 Share Posted October 25, 2004 I have put in a second rear de-cat pipe (first pipe at front still stock) I dont have a boost gague Am I OK on boost??? Car seems to run fine Cheers:) Link to comment Share on other sites More sharing options...
dude Posted October 25, 2004 Share Posted October 25, 2004 Get a boost guage fitted dude Dude:flame Dev Link to comment Share on other sites More sharing options...
Onelife Nofear Posted October 25, 2004 Share Posted October 25, 2004 from what i understand you should be fine if you still have one cat in! if you remove the other then j-spec are prone to overboosting but you can get away with putting in a restrictor to limit the boost until you get a boost gauge and then your boost controller. I just had mine fully decatted at last!!! :-) Link to comment Share on other sites More sharing options...
Jake Posted October 25, 2004 Share Posted October 25, 2004 Running with only one cat you will *probably* be OK boost-wise but there's no guarantee. Personally I'd get a boost gauge immediately, it's just not worth putting it off and you're going to have to buy one sooner or later. Link to comment Share on other sites More sharing options...
250horses Posted October 25, 2004 Author Share Posted October 25, 2004 if I over boost wont the stock fuel cut defender cut in ????? Its gonna take some time to obtain and install a boost gauge Link to comment Share on other sites More sharing options...
Alex Posted October 25, 2004 Share Posted October 25, 2004 You should be fine Charlie...if you haven't got an FCD fitted you can't do any harm. Link to comment Share on other sites More sharing options...
Grazer Posted October 27, 2004 Share Posted October 27, 2004 Ok - with one cat out I was hitting 1.5bar boost. I do not have an FCD and the ECU looks stock, so who knows why there was no fuel cut. Got down to 1.2 with a CW restrictor ring. Now that I am fully decat, I'm starting to hit 1.4 on cold days (with the restrictor ring in place). Guess I need a tighter ring (insert joke here). I would recommend a boost guage as I could of been driving around at 1.4 for a while. Link to comment Share on other sites More sharing options...
Alex Posted October 27, 2004 Share Posted October 27, 2004 You cannot hit 1.5bar with an FCD. Does your ECU have a gold stocker on it with MINES written on it? Link to comment Share on other sites More sharing options...
Grazer Posted October 27, 2004 Share Posted October 27, 2004 Originally posted by Alex Holdroyd You cannot hit 1.5bar with an FCD. You mean without? There's definitely no sticker on the ECU Link to comment Share on other sites More sharing options...
Alex Posted October 27, 2004 Share Posted October 27, 2004 Erm yeah without...hmmm....it's voltage driven. When the ECU reads a specific voltage from the MAP sensor it shuts off the fueling...FCD's clamp the signal so it never (or delays) reaches that voltage. However an aftermarket ECU like a Mines has the FCD integrated into it. Bit confused about you hitting 1.5bar... Link to comment Share on other sites More sharing options...
Steve W2 Posted October 27, 2004 Share Posted October 27, 2004 Originally posted by Alex Holdroyd Bit confused about you hitting 1.5bar... Does seem strange, maybe he was using the boost gauge of his BMX hand pump:p Graduations in 0.5 Bar increments:p A real cheap and shitty pressure gauge thats had some abuse would do the trick. Link to comment Share on other sites More sharing options...
Grazer Posted October 27, 2004 Share Posted October 27, 2004 Originally posted by Alex Holdroyd Bit confused about you hitting 1.5bar... So am I!! Is it possible to tamper with/reprogramme the stock ECU? This is what it looks like: http://homepage.ntlworld.com/gcsimpson/2004_08_rewiring02_resize.JPG Link to comment Share on other sites More sharing options...
Grazer Posted October 27, 2004 Share Posted October 27, 2004 Originally posted by Steve W2 A real cheap and shitty pressure gauge thats had some abuse would do the trick. Greddy boost guage in good nick Link to comment Share on other sites More sharing options...
Alex Posted October 27, 2004 Share Posted October 27, 2004 What's the GReddy lump ontop of the ECU? Link to comment Share on other sites More sharing options...
Grazer Posted October 28, 2004 Share Posted October 28, 2004 Originally posted by Alex Holdroyd What's the GReddy lump ontop of the ECU? EGT gauge box Link to comment Share on other sites More sharing options...
