Robbie Posted June 26, 2007 Share Posted June 26, 2007 Would I need to re-shim the head...all 24 if I fit HKS 264 cams or will the be OK? (This is on a standard JDM engine) The reason I'm asking is the cost involved for a reshim would make putting in 264's too expensive. Link to comment Share on other sites More sharing options...
Digsy Posted June 26, 2007 Share Posted June 26, 2007 You can't guaratntee the clearances will be the same so you should re-shim, but I'll bet the most people don't. I'd at least measure the clearances after you trial fit the cams. Link to comment Share on other sites More sharing options...
Robbie Posted June 26, 2007 Author Share Posted June 26, 2007 Hmm! thanks. What are the tolerances/clearances by the way? Link to comment Share on other sites More sharing options...
Alex Posted June 26, 2007 Share Posted June 26, 2007 There should be a sheet with the cams according to CW. Link to comment Share on other sites More sharing options...
Robbie Posted June 26, 2007 Author Share Posted June 26, 2007 Good stuff. Cheers Alex. Link to comment Share on other sites More sharing options...
Alex Posted June 26, 2007 Share Posted June 26, 2007 I think Gamer posted up a copy of the page the other day if you do a search Link to comment Share on other sites More sharing options...
