markrzs Posted June 23, 2007 Share Posted June 23, 2007 In the near future i'll be replacing my f & r pads, discs and fluid but i can't find a good guide on bleeding the brake system Does anyone know of a idiots guide for me to follow or any advice ? Thanks, Mark Link to comment Share on other sites More sharing options...
bignum Posted June 24, 2007 Share Posted June 24, 2007 I use 1 of those easy bleed kits but had to modify the reservoir cap to fit, then pressurise the system with a spare tyre and bleed away,,,,,, easy. Link to comment Share on other sites More sharing options...
ukApache Posted June 24, 2007 Share Posted June 24, 2007 start at the near side rear, then off side rear, then near side front & off side front. also dont let the reservoir go below the lower limit Link to comment Share on other sites More sharing options...
markrzs Posted June 24, 2007 Author Share Posted June 24, 2007 Thanks guys, are those kits from Halfords any good ? Link to comment Share on other sites More sharing options...
colsoop Posted June 24, 2007 Share Posted June 24, 2007 good guide here: http://www.teamscr.com/brakes.htm Link to comment Share on other sites More sharing options...
markrzs Posted June 24, 2007 Author Share Posted June 24, 2007 perfect ! thanks Col One more thing .....how much brake fluid should i buy ? Link to comment Share on other sites More sharing options...
AndyT Posted June 24, 2007 Share Posted June 24, 2007 perfect ! thanks Col One more thing .....how much brake fluid should i buy ? Think capacity is quoted as 1.5 litres. So buy 2 litres. Dot 5.1. Link to comment Share on other sites More sharing options...
ukApache Posted June 24, 2007 Share Posted June 24, 2007 for a complete flush i'd def have 2L to hand but you'd prob only use just over 1L Link to comment Share on other sites More sharing options...
markrzs Posted June 24, 2007 Author Share Posted June 24, 2007 cheers guys Link to comment Share on other sites More sharing options...
