robin Posted June 4, 2007 Share Posted June 4, 2007 Recently i've been doing a bit of work on the car and every time I recconect the battery the alarm goes off. It's not a problem; just a pita I have a small barrel key which I assume is to set the alarm to valet mode but where do I use the key?? I've found the alarm siren right near the battery but cant figure out where to put the key to disable the alarm. Any ideas? I think its the stock alarm system on a UK Spec. Link to comment Share on other sites More sharing options...
ivan Posted June 4, 2007 Share Posted June 4, 2007 There may be a plastic cover over a keyhole on the siren part. Link to comment Share on other sites More sharing options...
robin Posted June 4, 2007 Author Share Posted June 4, 2007 Thanks. I will have a look when it gets light. Link to comment Share on other sites More sharing options...
robin Posted June 8, 2007 Author Share Posted June 8, 2007 I found the key hole; its a stock toyota system as it has a toyota logo on it. turning the key seems to have done nothing. The alarm is still active and comes on any time the ignition has been switched off and then a door opened. Also the alarm has sounded for a second or so a couple of times while driving... think it might be a bit broken. Link to comment Share on other sites More sharing options...
