TRD Thermostat Installation
bolarbag
Dont have any pics, but its a simple job, drain coolant and rempve bottom rad hose, then undo the 2 bolts that hold the thermostat housing in place. Take out the old thermostat and put the TRD one in, making sure you fit it the right way round. Then put it all back together and refil with coolant. Its a much easier job if you remove the alternator first as well.
