Voo51 Posted May 29, 2007 Share Posted May 29, 2007 i have 1 JBL PX300.4 Amplifier, fully boxed with alll instructions and accessories. Again, this is top quality amplifier. It is not to be mistaken with the GTO series and this is the model up and one of thetop models JBL do for series power amplifiers. It is hardly used, no marks or scartches of any kind, mint condition. spec; PX300.4 600-Watt 4-Channel Power Amplifier With Electronic Crossover Slope-selectable variable electronic crossover - Each of the Power Series amplifiers is equipped with a variable electronic crossover capable of setting the slope rate at 12Db or 24dB per octave. The crossover adjustment range is from 32Hz to 320Hz. This allows for optimum vehicle and subwoofer tuning to a specific vehicle cabin. Dynamic Bass Optimization™ (DBO) circuit - This provides variable filtering with adjustable ¿Q¿ below 100Hz, far beyond conventional ¿Bass Q¿ circuits, by allowing the lowfrequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure's tuned frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized. This circuit is also fully defeatable in the event outboard processors are being used. Direct-Connect - Allows the use of 4 - 8-gauge power and ground cable to ensure enough juice is being delivered. No need for adapters or special fittings. Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitters needed! Common-dimension amplifier footprints - By designing all of the Power Series amplifiers with two common dimensions, the amount of space occupied in multiple-amplifier mounting applications can be optimized. Internal-lighting-ready - Each model is equipped with internal lighting mounts in the event that internal lighting is desired. General Power Output 123,5W x 4 into 4 ohms 169W x 4 into 2 ohms 358W x 2 into 4 ohms, bridged Max Power 600W Peak x 2 Signal-to-Noise Ratio >95dB Total Harmonic Distortion 0.04% Frequency Response 10Hz - 45kHz ±1dB Built-in variable electronic crossover with selectable slope Dynamic Bass Optimization™ (DBO) circuit Preamp outputs Differential inputs Internal-lighting-ready Direct-Connect Dimensions (H x W x D) 312mm x 432mm x 66mm When i boughtthis it was £350 now £300 inshops . I need to sell this amp as im raising money for my first house so OFFERS PLEASE!!!! Link to comment Share on other sites More sharing options...
Voo51 Posted May 30, 2007 Author Share Posted May 30, 2007 Ideally offers above £100 please. Link to comment Share on other sites More sharing options...
