b_have Posted May 21, 2007 Share Posted May 21, 2007 Anyone fitted/using one of these? Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 22, 2007 Share Posted May 22, 2007 A certain red Supra runs it Link to comment Share on other sites More sharing options...
b_have Posted May 22, 2007 Author Share Posted May 22, 2007 A certain red Supra runs it Can you tell us more Gaz? I'm guessing it doesn't transform the whole selection to sequencial. How does it work? Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 22, 2007 Share Posted May 22, 2007 Can you tell us more Gaz? I'm guessing it doesn't transform the whole selection to sequencial. How does it work? It locks the first 4 gears into a sequence that cannot be screwed up basically. Its designed for drag racing only, its not really any use for anything else. So you select first, lock the collar into position. When you want to change to second you wack it straight back, push straight up to get third and straight back to get forth. Its a good bit of kit! Gaz. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 22, 2007 Share Posted May 22, 2007 It locks the first 4 gears into a sequence that cannot be screwed up basically. Its designed for drag racing only, its not really any use for anything else. So you select first, lock the collar into position. When you want to change to second you wack it straight back, push straight up to get third and straight back to get forth. Its a good bit of kit! Gaz. Sounds like it be good for track days too Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 22, 2007 Share Posted May 22, 2007 Sounds like it be good for track days too I doubt it - you can't go from 4th to 2nd etc with disengaging the collar first so it would be a bit of a pain! Gaz. Link to comment Share on other sites More sharing options...
Wez Posted May 22, 2007 Share Posted May 22, 2007 For trackdays maybe the 6 speed Dog Engagement Gear Set from Pfitzner would be better. http://www.ppgearbox.com.au/html/products.htm#5 Link to comment Share on other sites More sharing options...
