PAG Posted May 21, 2007 Share Posted May 21, 2007 Hi lads just a quick couple of questions regarding the active spoiler. 1.Can it be fitted to an N/A 2.Is it a straight forward job 3.How is the ecu for it fitted Any help would be greatley apreciated.Cheers. Link to comment Share on other sites More sharing options...
colsoop Posted May 21, 2007 Share Posted May 21, 2007 Hi lads just a quick couple of questions regarding the active spoiler. 1.Can it be fitted to an N/A 2.Is it a straight forward job 3.How is the ecu for it fitted Any help would be greatley apreciated.Cheers. Yes, assuming you have everything required (including the proper undertray) yes quite straight forward, remove the headlights, manoveure the spoiler brackets up the inside of the headlight holes and on the chassis legs you will see several thread holes (12 mm) this is where the brackets mount. If you remove the dash panels it sits behind the radio, although if you are retrofitting it you may not have the loom or ECu, use the manual wiring diagram so you can control its use.(see attached) Link to comment Share on other sites More sharing options...
PAG Posted May 21, 2007 Author Share Posted May 21, 2007 cheers bud i think il give it a go then i can get the loom and ecu so i should just need the tray and the spoiler and job done? Link to comment Share on other sites More sharing options...
SIMON LC Posted May 21, 2007 Share Posted May 21, 2007 Did mine last month and pretty straight forward.Use that wiring diagram and you will be ok. Link to comment Share on other sites More sharing options...
PAG Posted May 22, 2007 Author Share Posted May 22, 2007 Cheers guys il give it ago and see how i get on.Its the ecu and switch not the loom as i said before.So the only other parts i will need will be the spoiler,undertray and either get a loom or make one up is that correct? Link to comment Share on other sites More sharing options...
PAG Posted May 24, 2007 Author Share Posted May 24, 2007 Link to comment Share on other sites More sharing options...
miko_supra Posted May 25, 2007 Share Posted May 25, 2007 just fitted my active spoiler. went on fine. had to take away a couple of plastic parts behind the bumper to make room for it though. no big deal though. havnt wired it into the ECU yet. Link to comment Share on other sites More sharing options...
PAG Posted May 25, 2007 Author Share Posted May 25, 2007 Good to know let me know when you have it working mate you can fill me in on any probs you came across if any. Link to comment Share on other sites More sharing options...
