help needed replacing intake manifold
hodge
Ive refitted my intake manifold after fitting a new engine and at abit of a dilema.
At the back of the inlet manfold bulkhead side theres 2 threaded holes and a larger centre hole. I cant remember what goes here. I thinks its a water pipe or something. Has anyone a pic of this or can offer me any advise. After fitting the whole engine myself I get stuck on the home straight.
Please Help.
The car is a j-spec. Im not sur if I explained myself probaly.
If you remove the plenuem and throttle body, you can see the intake manifold. there is 6 round pots on here which meet up and corospond to the plenuem when it is refitted. From the front to the back 1-6, after the 6th pot there is 2 threaded holes and a bigger centre hole. I just cant remember what went there.
Ok guys ive found a pic (thanks to simon B). Appanently its called an intake runner. If you look at the pic its the hole on the far right of the runner. like I said a 2 threaded holes and a bigger hole in the middle.
