clonking noise
erol_h
i have a 1993 j spec tt auto, the car is at the bodyshop at the moment and there telling me that they are hearing a clonking noise as they put the vehicle in reverse. Ive only had the supra for 3weeks and have only driven it once and do not remember no such noise is this normal please i would ne greatful for your advise thanks
The 'clonking' sound is quite common in Supras... mine clonks when I come to a stop on certain side sloping roundabouts..
I had the shocks replaced (well, not solely because of this!), subframe torque tightened (this is the most common cause), but still with the clonking... not loud, but just noticeable.
If you suspension set up is solid, check your sub frame... and then forget about it :p
