na to tt swap
hp006
Help needed.
My friend and i are doing a na to tt converion. The tt engine has gone straight in an everything fits fine. The garage who i brought the engine of said that the ABS and traction control unit does not need to be plugged in any where. Is this true, the engine currently will not start and i think it is this part of the wiring loom that is the problem.
Any suggestions.
Any way of by passing the ABS and traction control unit to make the engine go?
Shouldn't be a problem without the EBS or Trac connected. Do you have an Auto or Manual? As the Trac does have some links with the Auto box, but has been known to be removed.
Are you getting a spark?
Have you upgraded the fuel pump and ECU?
What parts have you actually changed over already?
Yes it was, slight issue with the wiring to start with but spoke with turbo fit and they sorted it out over the phone. I am waiting to see if i have to do any work on the gearbox. There is apparently a 50% chance that i will but i will wait and see. I am just waiting for the top radiator hose to arrive then i will test the car out.
The car has had the tt autobox put in which runs electronically where as the na runs via a cable. Hence there may be a chance that the car will get stuck in third and stall, but hoopefully will drive it soon and then i can let you know.
All the engines are the same, it is soley down to the ecu that you get with the engine. The na gearbox will go straight to the engine if its a manual but obviously you have to watch the power outout. You wont be able to tune the tt that much as the na wont take as higher power as the tt gearbox.
I would imagine the gearbox would take the tt normal bhp depending on the condition of your gearbox. I would'nt try and put more than stock power through the na manual though. BUt i am no expert, its only what research i have done.
So far the box and engine have done 219000kms but both seem fine i have replaced the clutch and the timing belt the engine oil never goes black i change it every 3 months and have been doing the box and diff oil yearly but would prob get it recond before the swap.
Guest nothingbetta
Im looking to do this also did you replace the engine yourself or did a garage do it for you? How much did the engine cost?
