r1george Posted May 4, 2007 Share Posted May 4, 2007 I want to replace my valve stem seals so I got in touch with Mr T and WOW how expensive, even from Steve Manley there over £100 just for the seals, but I can buy a complete top end gasket set aftermarket for £85 which includes the valve seals and camshaft seal plus loads more. My question are the aftermarket gasket sets any good and are we just being ripped off as usual by Mr T?? Carl Link to comment Share on other sites More sharing options...
AshBhp Posted May 4, 2007 Share Posted May 4, 2007 I want to replace my valve stem seals so I got in touch with Mr T and WOW how expensive, even from Steve Manley there over £100 just for the seals, but I can buy a complete top end gasket set aftermarket for £85 which includes the valve seals and camshaft seal plus loads more. My question are the aftermarket gasket sets any good and are we just being ripped off as usual by Mr T?? Carl The only aftermarket gasket sets i recommend is, Payen Gaskets. Which most good parts shops can get. Link to comment Share on other sites More sharing options...
Jake Posted May 4, 2007 Share Posted May 4, 2007 I got a "genuine Toyota" top end gasket set with a couple of gasket missing from eBay. When it arrived it clearly wasn't genuine Toyota and the quality of some of the parts was pretty poor. There's no way I would go to all the work of fitting valve stem seals and using unknown quality parts. How gutted would you be if it failed again a week later? Link to comment Share on other sites More sharing options...
