Guest Enola Gay Posted May 2, 2007 Share Posted May 2, 2007 When I get above about 60 mph the warning triangle on the dash comes on and off, sometimes very rapidly - almost always at same time as warning light showing one or both of the doors is/are open. Anyone any ideas as to what problem is and what solution maybe please? Link to comment Share on other sites More sharing options...
Guru Posted May 2, 2007 Share Posted May 2, 2007 Error codes? Link to comment Share on other sites More sharing options...
Guest Enola Gay Posted May 2, 2007 Share Posted May 2, 2007 what - you mean I should do all that stuff with wire or paper clip on diagnostic thingumaby and see what the error code shows ie number of blinks etc? If so where is the info when an error code has been obtained please ie if I have a code what do I do with it - presume some info somewhere telling what to do? Sorry I not very clued up on this... Link to comment Share on other sites More sharing options...
Animal Posted May 2, 2007 Share Posted May 2, 2007 I've just had a similar issue with my carbon doors. Look next to the catch on the edge of the door and you'll see a little plastic tab thing screwed on there. Thats the bit that pushes the little switch when the door is shut. My drivers side one had not been screwed down tight enough and had moved a little and every so often wouldn't operate the switch causing the warning light to flash. Link to comment Share on other sites More sharing options...
Guru Posted May 3, 2007 Share Posted May 3, 2007 There is a link when you click --> error codes Link to comment Share on other sites More sharing options...
