silvertt Posted April 26, 2007 Share Posted April 26, 2007 hi i have a fairly loud clicking noise on the rear drivers side that only appears when im braking, it only starts when im close to a stop? any ideas? i read a couple of posts but they are after people have changed things or not braking. thanks Mark Link to comment Share on other sites More sharing options...
Guest BornSlippy Posted April 26, 2007 Share Posted April 26, 2007 i get this on mine to on the rear more when im reversing i have looked at everything and its all ok dont worry to much mine has done this from when i got it Link to comment Share on other sites More sharing options...
silvertt Posted April 26, 2007 Author Share Posted April 26, 2007 yer it started this morning will have to inverstigate, i already got to do the cambelt and the brakes all round this month, but hopefully the brake change will sort the noise Link to comment Share on other sites More sharing options...
Guest Lowraj Posted June 15, 2007 Share Posted June 15, 2007 I have been having what sounds like the exact same problem for a couple months now. When i brake, particularly at low speeds i get a loud clicking noise from the wheels. It appears to come from all the wheels tho not simultaenously. Sometimes it can be just one wheel but sometimes it can be all four in succession. It varies in volume but can be almost a bang every now and then. I have had new pads, and discs fitted and had the pads fitted with a "fitting kit". This was all done at a garage btw not by me. None of this seems to have fixed it. After the fitting kit was used the brakes seemed a bit firmer and the clicking was less regular but within a couple weeks it was worse than ever... This is starting to drive me nuts, cos my car sounds like a banger whenever im slowing down... Link to comment Share on other sites More sharing options...
