Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 got some tein superstreets today will be fitting them tomorrow evening so pics will follow.. and erm, thats it! Link to comment Share on other sites More sharing options...
Jive Posted April 25, 2007 Share Posted April 25, 2007 Make sure you take some photos of the install process and do a write up for the Technical section Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 Make sure you take some photos of the install process and do a write up for the Technical section Sounds good i'll see if I can get a digicam and take lots of pics Link to comment Share on other sites More sharing options...
Jive Posted April 25, 2007 Share Posted April 25, 2007 Don't forget to do take pics of the old kit and the removal process and the install proces Good luck dude, hope it all goes well Link to comment Share on other sites More sharing options...
RedM Posted April 25, 2007 Share Posted April 25, 2007 got some tein superstreets today will be fitting them tomorrow evening so pics will follow.. and erm, thats it! Weren't the yellow Bilsteins coilovers then? Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 25, 2007 Share Posted April 25, 2007 Weren't the yellow Bilsteins coilovers then? excuse me? Link to comment Share on other sites More sharing options...
RedM Posted April 26, 2007 Share Posted April 26, 2007 woohoo i now have coilovers got some tein superstreets today will be fitting them tomorrow evening so pics will follow.. and erm, thats it! What did you have before? If it was stock then this from CW might interest you. The stock suspension is a coil over set up, Link to comment Share on other sites More sharing options...
JODY T Posted April 26, 2007 Share Posted April 26, 2007 Yes it is, all 4 are coil over spring... Perhaps Maz should have put up 'adjustable coilovers' Link to comment Share on other sites More sharing options...
Bob Posted April 26, 2007 Share Posted April 26, 2007 Sounds good i'll see if I can get a digicam and take lots of pics Damn. Sounds like I'd better have a shave today then. Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 26, 2007 Share Posted April 26, 2007 Damn. Sounds like I'd better have a shave today then. Haha yeah looks like it Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 26, 2007 Share Posted April 26, 2007 Yes it is, all 4 are coil over spring... Perhaps Maz should have put up 'adjustable coilovers' Yeah that! Link to comment Share on other sites More sharing options...
VELOCITY Posted April 26, 2007 Share Posted April 26, 2007 I got mine yesturday, would love to see some pics of your install, did you get the upper mounts to? Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 26, 2007 Share Posted April 26, 2007 nice one - all you need now is a Roof Spoiler and the car will be perfect Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 26, 2007 Share Posted April 26, 2007 I got mine yesturday, would love to see some pics of your install, did you get the upper mounts to? nah i didnt get the top mounts, so will be using oem ones. did you get them with top mounts? Link to comment Share on other sites More sharing options...
VELOCITY Posted April 26, 2007 Share Posted April 26, 2007 Yeah but mine for some reason came seperatly from the shock so have to built them up as you are going to have to do Link to comment Share on other sites More sharing options...
Guest mk47 Posted April 26, 2007 Share Posted April 26, 2007 Yeah but mine for some reason came seperatly from the shock so have to built them up as you are going to have to do build what up mate? i thought you can just use the existing stock top mounts? Link to comment Share on other sites More sharing options...
JODY T Posted April 26, 2007 Share Posted April 26, 2007 I thin he means that you will have to dismantle your coilovers so you can get the top mounts off then 'Build' the new ones up.. Easy job, but make sure the ride hight is set before they go on the car, makes it so much easier! Link to comment Share on other sites More sharing options...
Mas Posted April 26, 2007 Share Posted April 26, 2007 dont forget Tein says if you dont get it fitted by a qualified garage it wont be covered for Waranties etc ?!! Link to comment Share on other sites More sharing options...
VELOCITY Posted April 26, 2007 Share Posted April 26, 2007 I thin he means that you will have to dismantle your coilovers so you can get the top mounts off then 'Build' the new ones up.. Easy job, but make sure the ride hight is set before they go on the car, makes it so much easier! Yeah sorry thats what i ment Link to comment Share on other sites More sharing options...
