Help needed - wiring in Innovate LC-1 / XD-1 wideband
Bob
Well I've downloaded the manuals for each and certainly the LC-1 manual has a very helpful bit on wiring:
It has the wiring guides for both the cable with 6 stripped ends, and the cable with 7 stripped ends.
Strangely enough, I have a cable with 8 stripped ends - an extra black wire, so I have no idea which is the calibration wire and which one should be earthed.
Am I right in thinking the following:
Red - 12v ignition
Blue - ground
thin white - ground
yellow and brown - tape up and ignore (not using the output yet for logging)
thin green - ground, or tape up and ignore
Black - thick black to ground, thin black taped up and ignored
assuming that the thin black one is the calibration wire, not the thick black one.
Can anyone shed any light on this?
Cheers!
