Help! Headlight won't come out!
Elmo
I've tried wiggling, pulling and swearing but the bugger refuses to come out! The light is starting to fade so I've just took a bit more skin off my knuckles putting the bolts back on. All I want to do is change the bloody sidelight bulb!!
The supe is a great car, but it wan't designed for DIY repairs, the most basic jobs are a real pain in the arse!
You don't need to take the light units out to change the sidelight bulbs but, as said above, they need a fair bit of wiggling! I found that the two long studs which hold the lamps onto the wings can be a bugger to get off as the thread catches on the locator tabs. :(
Perseverance mate :) :)
I could'nt get my hand behind the light to get the bulb out so thought it would be easier to get the light out and have more room to change the bulb. The MOT man failed it today so I need to get it changed ASAP.
