Wazz72 Posted March 18, 2007 Share Posted March 18, 2007 Does anyone have a diagram of how to use the FCD on this. I have the harness, but would like instructions on fitting it in English. Had a reply ages ago on this question but the answer I got was more confusing. Also what can i measure with the other inputs on this? Link to comment Share on other sites More sharing options...
bondango Posted March 18, 2007 Share Posted March 18, 2007 Well 1st thing is you need the optional sensor harness. http://www.mohdparts.com/emanage/photos/profec_e-01_photos/opt2.JPG When you have this harness, you can use Analog input/output 1 (white and Green) to intercept the Pressure sensor signal to the ECU and clamp the Voltage.. http://www.mohdparts.com/emanage/manuals/profec_e-01_manual/26.jpg The sensor harness will also allow you to read any 0-5V voltage such as Throttle position as well as Freq. signals such as Speed. Link to comment Share on other sites More sharing options...
Wazz72 Posted March 19, 2007 Author Share Posted March 19, 2007 what do I connect the white and the green wires to? te pressure sensor on the E01? which wire is it? do i cut it? Link to comment Share on other sites More sharing options...
bondango Posted March 19, 2007 Share Posted March 19, 2007 The Stock pressure sensor signal wire..Pin 62 on the ECU IIRC (check the Technical Guides and FAQ's for ecu pinout diagram. Cut the Pressure sensor harness wire, Green wire attaches to Wire heading too ECU White attches to wire heading away from ECU Link to comment Share on other sites More sharing options...
Wazz72 Posted March 19, 2007 Author Share Posted March 19, 2007 Your a star thanks. Time to blow up my engine.. Link to comment Share on other sites More sharing options...
