Greddy e01 Help
Wazz72
Does anyone have a diagram of how to use the FCD on this. I have the harness, but would like instructions on fitting it in English. Had a reply ages ago on this question but the answer I got was more confusing. Also what can i measure with the other inputs on this?
Well 1st thing is you need the optional sensor harness.
http://www.mohdparts.com/emanage/photos/profec_e-01_photos/opt2.JPG
When you have this harness, you can use Analog input/output 1 (white and Green) to intercept the Pressure sensor signal to the ECU and clamp the Voltage..
http://www.mohdparts.com/emanage/manuals/profec_e-01_manual/26.jpg
The sensor harness will also allow you to read any 0-5V voltage such as Throttle position as well as Freq. signals such as Speed.
The Stock pressure sensor signal wire..Pin 62 on the ECU IIRC
(check the Technical Guides and FAQ's for ecu pinout diagram.
Cut the Pressure sensor harness wire, Green wire attaches to Wire heading too ECU
White attches to wire heading away from ECU
