clicking noise
supratoy
Unlikely but, I have TSW wheels and they have a false center nut for show which has a pin through, again for show, this does click which I notice sometimes with the window down.
Matt
Oh and im pretty sure its a "clickety clickety":D
i had exactly the same problem on a 200sx, it had been fitted with flush valves on the wheels and one of the locking nuts inside the wheel had fallen off so was free to do its thing and piss me off know end inside the wheel, at speed it went due to centrifugal force holding it the inside of the wheel, it was in the garage all day and cost me about £70 in labour for a 20p nut, might be worth a look at
Originally posted by supratoy
oh yeah when iam turning or sometimes driving with the window down, i can hear a clikcking noise , it does'nt get louder or anything but its does'nt always click just now and then thanx
Check your power steering fluid level if its a bit low on extremes of turning it can cause clicking as the pump finds no fluid to pump. Might also be a dodgy power steering pump.
Check your front lower wishbone bush bolts, the rear ones that you can see thorough the wheel arch behind the wheel if you understand, you'll probably need a ramp though to get some serious leverage behind it but it works :)
I hope you understood that, i got a pic of it, i'll try and post it, but TRD3000 posted it a few weeks back for me!!
Graham..
