wwe Posted February 6, 2007 Share Posted February 6, 2007 hi all i have a problem a code 42 speed sensor signal circuit o/d off light flashes & engine light & big red warning light comes on i have had wires checked sensors checked a new ecu (second hand) new speedo clocks (second hand) still not fixed apart from getting the sensors changed anyone know what else i can do ?????????????/ Link to comment Share on other sites More sharing options...
flukey-lukey Posted February 6, 2007 Share Posted February 6, 2007 A search on here for a code 42 fix maybe? http://www.mkivsupra.net/vbb/showthread.php?t=72588&highlight=code+fix Link to comment Share on other sites More sharing options...
wwe Posted February 6, 2007 Author Share Posted February 6, 2007 thanks mate will read all may take me some time lol Link to comment Share on other sites More sharing options...
flukey-lukey Posted February 6, 2007 Share Posted February 6, 2007 The solution is more or less in the first post Link to comment Share on other sites More sharing options...
gjp Posted February 6, 2007 Share Posted February 6, 2007 I fixed this by fitting a new and better speedo converter. http://importsolutions.co.uk/SCU/SCU_make.asp Link to comment Share on other sites More sharing options...
wwe Posted February 6, 2007 Author Share Posted February 6, 2007 i dont have a coverter on the car i do have one just not fitted yet Link to comment Share on other sites More sharing options...
flukey-lukey Posted February 6, 2007 Share Posted February 6, 2007 i dont have a coverter on the car i do have one just not fitted yet try fitting it first and see how you get on Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted February 6, 2007 Share Posted February 6, 2007 In some old threads you'll see i've had this problem and did the code 42 fix as attached - which did solve the symptoms , i.e low idle speeds and power steering problems , yet i'm not 100% happy as every now and again its as if the cars not quite right so if i was you i wouldn't bodge it -which this fix is in a fashion . i'd go for a thor delimeter as these are the ones that sort power steering too Link to comment Share on other sites More sharing options...
