Rich Posted June 19, 2004 Share Posted June 19, 2004 Gutted:( First I found out my turbos have gone and today ive just found out there has been detonation in my engine and now I need a new engine because the pistons and bore are damaged,does anybody have a spare engine in good condition lying around?? Link to comment Share on other sites More sharing options...
Syed Shah Posted June 19, 2004 Share Posted June 19, 2004 Not common on these cars, and nigh on impossible with proper tuning etc. So, what boost did you run? AFRs? Who tuned it? This should not happen, and I would get to the bottom of it first before throwing in another engine. Link to comment Share on other sites More sharing options...
Darren Posted June 19, 2004 Share Posted June 19, 2004 Ive posted this before but Jap Cars in Hythe, Kent stock most Jap engines..They have normal Supra engines and 6 VVTI engines on the shelf or find a breaker somewhere but thats not going to have any guarantee. Link to comment Share on other sites More sharing options...
Rich Posted June 19, 2004 Author Share Posted June 19, 2004 was running 1.2 bar with restrictor ring,and both turbines were shattered ,mechanics done a compression test abd dropped 2 pistons and a leak coming from the bore. Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 19, 2004 Share Posted June 19, 2004 With 660 injectors that really shouldn't have happened. I agree with Syed, its most likely a set-up problem with the fuelling. Sorry to hear of your problems, but get it checked out when the new engine a turbos get fitted. Don't just fit them and run in the same state of tune. Link to comment Share on other sites More sharing options...
Syed Shah Posted June 19, 2004 Share Posted June 19, 2004 1.2bar and det? I think you were running lean. Did you ever check AFRs with a WB? Link to comment Share on other sites More sharing options...
MONKEYmark Posted June 19, 2004 Share Posted June 19, 2004 Originally posted by Syed Shah 1.2bar and det? I think you were running lean. Did you ever check AFRs with a WB? he is a new supra owner and may not know about tuning. could it be a failing fuel pump? Link to comment Share on other sites More sharing options...
ChrisR Posted June 19, 2004 Share Posted June 19, 2004 Originally posted by Syed Shah 1.2bar and det? I think you were running lean. Did you ever check AFRs with a WB? And theres you ABC's and 123's. Give me a clue what WB is then. Link to comment Share on other sites More sharing options...
Darren Posted June 19, 2004 Share Posted June 19, 2004 Originally posted by ChrisR And theres you ABC's and 123's. Give me a clue what WB is then. WIDEBAND think they use it for checking fueling etc....HTH Link to comment Share on other sites More sharing options...
Rich Posted June 19, 2004 Author Share Posted June 19, 2004 The problem has occured when it was standard fuel system and standard ceramics with restrictor ring.All those bits were in the process of getting fitted now .On the original diagnosis he thought that it was the turbos because that is a known weakness,but he did a compression test this morning which showed the problem up. Link to comment Share on other sites More sharing options...
ChrisR Posted June 19, 2004 Share Posted June 19, 2004 Originally posted by Darren WIDEBAND think they use it for checking fueling etc....HTH Cool, im afraid im not up on all the terms and abbreviations Link to comment Share on other sites More sharing options...
Syed Shah Posted June 19, 2004 Share Posted June 19, 2004 What mods were on at the time? Just decat/exhaust/1.2bar? AFRS: Air to fuel ratios. A wideband is a sensor for measuring them (across a great range, not just stoich or rich). If that was the case, then perhaps you were running lean, apparently this does happen on J-specs (as opposed to UKs rich run rich). Link to comment Share on other sites More sharing options...
Darren Posted June 19, 2004 Share Posted June 19, 2004 Run lean, shag your engine not just your turbos its an expensive mistake to make. Hope you get it all sorted. Link to comment Share on other sites More sharing options...
dangerous brain Posted June 20, 2004 Share Posted June 20, 2004 If its any consolation I am looking for an engine and there is quite a large choice to go for. I am tempted to go for the one that Michel of the forum has as its coming from a known source. It wont be hard to find another motor, just wont be cheap to do the whole job. Link to comment Share on other sites More sharing options...
ardasaliah Posted June 20, 2004 Share Posted June 20, 2004 I think there is an engine on ebay at mo Link to comment Share on other sites More sharing options...
dangerous brain Posted June 20, 2004 Share Posted June 20, 2004 There are two or three one with all the kit on it which looks a bit tatty and a UK bare engine that martin from the darkside is selling. There is a guy oop north selling one also complete with all the stuff on this is a UK with UK turbo's. Link to comment Share on other sites More sharing options...
