B04D - axle code
Guest ljluki
There are no NA UK spec cars.
And the code you mention doesn't exist either.
AXLE Example Description
Crown Wheel Size = A (8'' - 203mm), B (8.7'' - 221mm)
Differential Ratio = 01 (4.083:1), 02 (3.769:1), 03 (3.267:1)
Differential Type = A (Standard open differential), B (Torsen LSD)
thanks,
I know...http://www.mkiv.co.nz/specs.htm
but i saw this code on engine tag information.
Maybe something about diff ratio??
It's quite possible that it's the same differential. This one is from ebay too. But the seller have N/A supra-broken. I think that code is correct beacause I saw this code in my friend's car a few years ago. It was N/A auto....Thanks for any suggestion especialy about diff ratio
  • 4 weeks later...
